  • webmarketingguy Friend
    #194594
    Hello, I can’t seem to figure out the solution to this issue. On the JA VM Products module I have an issue. All of the products have custom fields for sizes (Small, Large, XL, etc etc). The problem is that when the customer selects a size for an item the price changes for all of the items before they “add to cart” and that should not be happening. How can this be fixed?
    Also on the product page the custom fields do not show. I will attach screenshots. Thanks for your help;.
    1. screen
    Did you try to switch default template to a standard template of Joomla like Beez? then try to select the size again. This will help to figure out where the issue come from VM or our template
    calavaro Friend
    #522744
    I used to have this problem.
    For each child product, edit it, set the price separately (delete any price settings in the parent product – you may have price overrides there).
This topic contains 3 replies, has 3 voices, and was last updated by  calavaro 10 years, 10 months ago.
