  • eziolkowska Friend
    #1064266
    I was moving page from localhost to the server.
    The page is using template ja simpli.
    After the transfer file, database and configuring the page I do not see any custom styles (only from Front – on admin page everything is visible correctly).
    There is no logo, no fonts, no background for fixed header and footer.
    Any idea what is more to change to enable custom.css.
    I am thinking about this problem from few weeks and have no more ideas…
    Pankaj Sharma Moderator
    #1064309
    I am not sure if there is something wrong when you restore the site.
    Can you use Akeeba backup extension to take backup and restore the backup file on the server?
    if still, you found the issue share the temp. superuser details and URL in the private reply,
    I will check it further.
This topic contains 1 reply, has 2 voices, and was last updated by  Pankaj Sharma 7 years, 1 month ago.
