  • thatch10 Friend
    #187915
    Any of the products with variants will not add to the cart, Also unable to change the quantity. This appears to be related to the template and Jquery issues.
    Is there anyone else able to set up the custom variants plugin with stock control and keep the add to cart and qty options still working please?
    I have tried this with the standard install with the same results.
    Changing the template allows the custom variant plugin to work and the quantity to be changed
    Thatch
    MoonSailor Friend
    #494524
    HI thatch10,
    When i check your site, “add to cart” is running normal.
    Can you describe the error details?
    <blockquote>
    I also have issues with the logo not displaying on some pages due to a <h2> tag instead of a <h1> However I have asked this in the forum.
    </blockquote>
    When change h2 tag instead a h1, i believe logo will show normal. <blockquote>displaying on some pages </blockquote> pls give the url’s to me.
    Regards.
    marklimonbay Friend
    #510277
    Hallo Thatch10,
    Could you find a solution for this? I have exactly the same problem here.
    Edited:
    Solved in http://www.joomlart.com/forums/topic/custom-stockable-variants-plugin-seems-not-to-work/#post-495124
This topic contains 3 replies, has 3 voices, and was last updated by  marklimonbay 11 years, 2 months ago.
