pba2006 Friend
pba2006
- May 2012
- 3 times in 1 posts
October 8, 2012 at 7:37 pm #181277Hello,
In our site at http://www.akankshajunction.com, when users click Customize my page under the Profile menu, the page to add applications appears. When users click Add Application, the Add application window appears with applications listed. However, when users click Add to add application, nothing really happens. The applications do not get added to the user’s page.
Request your help in resolving this, please.
Thank you
Warm regardsPraveen
Saguaros ModeratorSaguaros
October 9, 2012 at 4:24 am #469497Hi Praveen,
Did it work with default joomla template? Please try to switch default template to another instead of JA Social to check it.
and may I know which versioni of JomSocial component you are using?
pba2006 Friendpba2006
- May 2012
October 9, 2012 at 2:33 pm #469547Hello Saguaros,
I am using Jomsocial 2.6. This turned out to be a conflict with an installed plugin – jspcup_community (JAchievements in User Profile – http://shop.progmist.com/products/jachievements/jachievements). Am planning to play around with the JAchievements source code to see if I can resolve the issue.
Thanks for helping out.
Warm regards
Praveen
October 10, 2012 at 3:21 am #469586Hi Praveen,
So please try with it and let me know if you need further assistance.
AuthorPostsViewing 4 posts - 1 through 4 (of 4 total)This topic contains 4 replies, has 2 voices, and was last updated by Saguaros 12 years, 3 months ago.
Problem with Customize my Page to Add Applications
