  • alsatisa Friend
    #136390
    Hi!
    I have my bussiness site and I have a problem. My site is based on Joomla 1.0 and on (as you know) JA_Corona template. So… I can simply change for com_frontpage menu link the description, that template then shows (in right menu). But the problem occurs, when i try to do the same for other Components, such as fireboard etc. The problem is that, when you link that component no additional parameters are shown in right window. So i can’t change the Menu image or add a description. The temporary fix was with static links to components so I could atleast add the image, but still the description is missing (not to mention, when the Forum is selected, it still shows the Home menu). >:(
    Any solutions?
    alsatisa Friend
    #283950
    Hehehe… no answer after three days… it’s that big problem?
    erwinderuiter Friend
    #283960
    I also post a problem on 3 december 2008, and still no answer…. (http://www.joomlart.com/forums/topic/alternative-text-read-more-in-ja-corona/)
    alsatisa Friend
    #283965
    It really is strange, to create a template, which has a menu that looks good with images, but it doesn’t work for most components (fireboard, docman etc.). These really should have a fix :/
This topic contains 4 replies, has 2 voices, and was last updated by  alsatisa 16 years ago.
