  • Valentino Friend
    #205913
    Hello everyone , I have two questions to ask yourself :
    1 – How do I put the logo in svg format ? I wanted to use this format to have more definition . I attach the photo to better understand :
    2 – I have created a form with html code , this module takes the style code from the file custom.css , is published in the area ” features- intro2 ” and works well , as in the following :
    But I want to load this module in an article by the tag { loadposition features- intro – 2 } , but the module is not loaded properly , you see this:
    it would seem that it does not read the code custom.css , the background should be blue .
    Custom.CSS:
    .background-blue-dark {
    background-color: #1352a1
    color: #ffffff
    font-size: 20px;
    Thanks !
    1. image1
    2. image2
    3. image3
    Ninja Lead Moderator
    #568798
    #1) I’m so sorry this because the logo in svg format could not support
    #2) If you want to loadposition to work, you have to set Prepare Content: YES
    about css style on your site, I see it works but you add wrong class because it need blank space in first line, see the screenshot
    1. Screen-Shot-2015-04-29-at-17.24.55
    2. Screen-Shot-2015-04-29-at-17.22.34
    #733891
    Valentino Friend
    #568971
    Sorry , I still have a problem , I followed your instructions , but the module loaded on the page does not appear in full screen , in the home works fine .
    Homepage, correct module in fullscreen
    Page article , incorrect module
    What interests me is to create the colored bands fullscreen within articles that contain HTML code .
    Thanks !
    1. home
    2. page
    Valentino Friend
    #734062
    Thanks !
    #569058
    Which area are you referring to on your site? Things at least look to be running smoothly from what I can see the problem on page article.
    Valentino Friend
    #569121
    I refer to the module ” Contacts Index” , in the two photos you see the difference , I want a fullscreen view of this module in the article.
    #569257
    <em>@valentino.craviari 471423 wrote:</em><blockquote>I refer to the module ” Contacts Index” , in the two photos you see the difference , I want a fullscreen view of this module in the article.</blockquote>
    I checked on your site but “Contatti Index” module (features-intro-2 position) only showed with Home page and could not see it appears with other pages on your site. You can assign that module with other pages.
    #734346
    Valentino Friend
    #569882
    <em>@Ninja Lead 471661 wrote:</em><blockquote>I checked on your site but “Contatti Index” module (features-intro-2 position) only showed with Home page and could not see it appears with other pages on your site. You can assign that module with other pages.</blockquote>
    I used ” Contact index” just for example , what they really want to do is create the colored bands that include text and images on a page , these colored areas must extend the full length of the page , should not be seen with white stripes sides , as shown in the two photos attached .
    thanks
    #569893
    You can add all configuration on that module and give me the URL of your site so that I can take a look.
    I checked on “Contatti Index” module but I did not see the difference
This topic contains 11 replies, has 2 voices, and was last updated by  Ninja Lead 9 years, 7 months ago.
