Tech-xml Friend
Tech-xml
- October 2010
- 5 times in 2 posts
December 11, 2015 at 1:21 am #799957I need a solution that will not cause trouble on the home page of the site. Creating space between the main menu and module ACM HERO Video.
December 11, 2015 at 4:05 am #801086Hi on Homepage of site , i did not found any issue . While on forum page i noticed the content is behind the header , you can fix it with adding this code in custom.css file
.com_kunena .t3-mainbody { padding-top: 50px!important; }
Hope it helps.
Tech-xml FriendTech-xml
- October 2010
December 11, 2015 at 12:29 pm #804056Solved, thanks
December 11, 2015 at 1:16 pm #804239Tech-xml FriendTech-xml
- October 2010
December 11, 2015 at 1:26 pm #804273I made the change in custom.css file
December 11, 2015 at 1:55 pm #804426Yes, where exactly can I find custom.css?
Edit: Nvm, found it tnx 🙂
AuthorPostsViewing 6 posts - 1 through 6 (of 6 total)This topic contains 5 replies, has 3 voices, and was last updated by ragykhairy 9 years ago.
