  • omniapublishing Friend
    #160658
    Hello! I have a problem with content
    I justify the article and in the code I look that the div is closed only at the and of article. So, on the frontend the columns go down, but if I close the div on the code and then I open a new div after read more, the columns came back on the right
    How can I do?
    aman204 Friend
    #378376
    Can you provide a link to your site
    Mainly, the div tags should go in sync i.e. if there are mismatches, it can tend to break the layout
    Ninja Lead Moderator
    #378382
    Here p tab justify code:
    <p style="text-align: justify;"></p>
    if you put div tab(open and close) uncareful tend to break the layout
    #378413
    #378421
    <em>@omniapublishing 223781 wrote:</em><blockquote>http://www.androiditaly.com</blockquote>
    The site looks fine, have you fixed the issue already?
This topic contains 5 replies, has 3 voices, and was last updated by  Ninja Lead 13 years, 10 months ago.
