  • loci Friend
    #168655
    Hello
    i have a strange problem that i’m trying to add a link on the main menu and when i save and see the change i see the slideshow article and content article two times in a page.
    if i look in the content article manger i can see only one copy of this article but if look on the browser i see double.
    http://www.casasassolo1713.com
    TomC Moderator
    #413303
    Not certain of the issue – as I am not seeing any duplicate articles or content when I look at your site.
    Is there a specific section/menu item we should be clicking to see this issue?
    loci Friend
    #413312
    i mean… if u look the slideshow i see two times write “citta e arte” like a two article
    i don’t have 2 article call it ” citta e arte”.
    and the same appear in the content
    ….but this is the same single article.
    thanks a lot
    1. Schermata-2011-09-17-a-20.18.59
    2. Schermata-2011-09-17-a-20.19.13
    TomC Moderator
    #413315
    Hmmmm …. Any change you can put up a screenshot of your Slideshow module configuration?
    loci Friend
    #413322
    we could also write by skype if u prefeer.
    thanks a lot
    1. Schermata-2011-09-17-a-20.39.22
    2. Schermata-2011-09-17-a-20.39.42
    TomC Moderator
    #413324
    How have you selected the articles you want to display within your slideshow?
    Which articles have/did you select?
    loci Friend
    #413329
    The slideshow select category is – slideshow
    and the content is the default article choose in the Article featured or category “appartamento a bologna”.
    in every of this category now is pubblish only one article…Citta e arte in slideshow and Appartamento Bologna in article featured.
    loci Friend
    #413333
    i have solved the problem.
    i have linked the same user to two different contact.
    i have find another thread that explain the problem.
    anyway thanks a lot
    bye
This topic contains 8 replies, has 2 voices, and was last updated by  loci 13 years, 1 month ago.
