msilac Friend
msilac
- October 2010
- 5 times in 1 posts
March 20, 2013 at 7:03 am #186021I have a problem with placing more images in Joomla Articles and K2 articles. Whether I use the Tiny MCE or JCE editor, when I try to add a picture trough the editor or by manually adding the path happens next
images/galerije/drzavno_prvenstvo_2012_mala.jpg
“images/galerije/drzavno_prvenstvo_2012_mala.jpg”
So, editor adds two slashes and of course because of that the picture will not be displayed. That’s what happens when you click Save in the article. And every time when I click save it adds another two slashes 🙂
Attached is an example of how it looks in the article. I did not to upgrade components or plugins.
What to do?
http://www.vk-iktus.hr/vk-iktus/upis-clanova
EDIT: Now i see same thing is with links in articles…
- msilac Friend
msilac
- October 2010
March 20, 2013 at 7:25 am #487147And in slideshow lite module
One more note… i Am just changed in global configuration – SEO settings “Use URL rewriting” but before that I Am changed htacces.txt to .htacces
msilac Friendmsilac
- October 2010
March 20, 2013 at 8:13 pm #487254I guess I enabled something I should not enable 🙂
Anyone knows?
Stork11 FriendStork11
- March 2011
- 431 times in 393 posts
March 21, 2013 at 8:28 am #487308Hello msilac,
Please try to set “magic_quotes_gpc=off” in your PHP configuration.
Hope this helps.
Regards.
msilac Friendmsilac
- October 2010
March 21, 2013 at 9:53 am #487332Thx for answer,
I see in System information – Relevant PHP Settings that magic quotes is ON. But dont know where to turn of? Is it a chance that something is wrong in my .htacces file?
- March 2011
March 21, 2013 at 10:08 am #487335<blockquote>Is it a chance that something is wrong in my .htacces file? </blockquote>
Maybe, please find this text “php_flag magic_quotes_gpc off” in your .htaccess file.If above text is not in .htaccess file, please ask your hosting provider to turn it off.
Regards.
msilac Friendmsilac
- October 2010
March 21, 2013 at 11:52 am #487351Nope, hosting provider is turning off magic quotes gpc but that not helps…
- March 2011
March 22, 2013 at 5:02 am #487408Magic quotes PHP setting is still on. Please re-check my screenshot.
Regards.
1 user says Thank You to Stork11 for this useful post
msilac Friendmsilac
- October 2010
March 22, 2013 at 6:01 am #487411I really need help about this… this is live site and I can add links, pictures… is someone can look at site administration, maybe I missing something
msilac Friendmsilac
- October 2010
March 22, 2013 at 8:37 pm #487515Yes, that was a problem, now it is off and everything is ok.
Thank you
AuthorPostsViewing 10 posts - 1 through 10 (of 10 total)This topic contains 10 replies, has 2 voices, and was last updated by msilac 11 years, 9 months ago.
Problem with editor and pictures
