  • thatch10 Friend
    #156082
    I am experiencing problems getting JA Rave to display Front end editor JCE, JCE displays fine in the backend.
    It has meant that I am trying various things to get the editor to work, revealing that a standard install from the JA Rave quickstart has a few erroneous entries
    Components
    K2 is enabled but Has no version, date or author suggesting missing files
    JA Comment is enabled but Comment Has no version, date or author suggesting missing files
    JA Extensions Manager is disabled and Has no version, date or author suggesting missing files
    Plugins
    Content – Highslide for Joomla! 1.5 Has no version, date or author suggesting missing files
    Content – JA Comment Has no version, date or author suggesting missing files
    Editor Button – JAComment OFF Has no version, date or author suggesting missing files
    Editor Button – JAComment ON Has no version, date or author suggesting missing files
    Search – JA Comments Has no version, date or author suggesting missing files
    System – JA Comment Has no version, date or author suggesting missing files
    I’ve managed to ftp up all of the missing files apart from the Content – Highslide for Joomla! 1.5, installing the highslide plugin http://www.joomlart.com/joomla/extensions/ja-highslide does not install the missing files.
    Tried installing this highslide plugin http://joomlanook.com/index.php?option=com_remository&Itemid=53&func=select&id=1 Still no fix to the missing file problem.
    Trying to uninstall the plugin Content – Highslide for Joomla! 1.5 gives the error ‘Plugin Uninstall: Manifest File invalid or not found’
    Don’t think that this will fix my editor problem, however would be nice to know where to get this plugin from.
    Also thought that you needed to know about the missing files in the quickstart.
    As an update, fixed problem with JCE editor with information found here http://www.joomlart.com/forums/topic/jce-editor-not-loading-in-jat3-2-0-framework-with-js-optimization-turned-on/
This topic contains 2 replies, has 2 voices, and was last updated by  Saguaros 14 years, 1 month ago.
