  • dsmj Friend
    #120265
    TinyMCE and Wysiwygpro on the new Teline template i just downloaded.
    its at http://nationalwriterssyndicate.com and i am happy with it
    it works well with the Expose gallery
    http://nationalwriterssyndicate.com/index.php?option=com_expose&Itemid=33
    Only one big hassle : the width control for the submission editors
    what/where does the editor control its window width?
    i cannot seem to control that width of 600 or 615 pixels,
    which runs into the sidebar withd a 1024 screen.
    the offending html in the page code
    <table id=”fulltext_container” width=”615″ height=”484″ class=”wpContainer” border=”0″
    cellpadding=”0″ cellspacing=”0″><tr>
    the screen grab: http://nationalwriterssyndicate.com/issues/submit-width.gif
    Thanks for any help – i have wasted hours trying to find and clobber the code that sets the wyswig editor width
    swemmel Friend
    #220129
    For TinyMCE I don’t know. And Wysiwygpro I never worked with. I use JoomlaFCK Editor and in this editor configuration you can set the width and height in pixels. Maybe it is worth to take a look at this one.
    Kind Regards,
    Peter
    kani Friend
    #222847
    Parse error: syntax error, unexpected ‘*’, expecting T_OLD_FUNCTION or T_FUNCTION or T_VAR or ‘}’ in /home/prowess/public_html/joomla/components/com_content/content.html.php on line 596
    This is error im getting. Anyone plz help me to solve this problem.:eek:
This topic contains 3 replies, has 3 voices, and was last updated by  kani 17 years, 6 months ago.
