  • marco17 Friend
    #150144
    i want to put a embed code of vimeo in a module to show it in the user5 position. The problem is that if i put the embed code of vimeo in the article it works but if i put the code in a custom module it doesn’t work.
    Any suggestion ?
    Many thanks.
    Dear marco17!
    Please disable the editor plugin. and then you ‘ll put the source code in the content of module. may be the problem is fixed
    Good luck
    marco17 Friend
    #339466
    Sorry, but whisch editor plugin i must disable ? There are: Editor – TinyMCE 2.0 , Editor – XStandard Lite 2.0 , Editor – JCE 1.5.1 and Editor – No Editor
    I have tried to disable each of them but nothing, the viemo video doesn’t work in the module.
    Marco
    marco17 Friend
    #340017
    any news about this problem ? Can you help me ?
    Thanks.
    Marco
    Anonymous Moderator
    #340077
    Hi marco17
    Edit your custom html module, in the description of module, you view with html mode. You copy html code into the textarea of pop up page and save again.
    if not, send me your admin account via PM so that i can check it for you.
This topic contains 5 replies, has 3 voices, and was last updated by Anonymous 14 years, 7 months ago.
