  • Pankaj Sharma Moderator
    #1078520
    Kindly open system > Global configurations > Default Editor > None.
    Now add the code to custom html module and save it.
    Editor removes the icon code, that’s the issue you are getting em on icon code.
    librandi Friend
    #1078577
    I tryed but it doesn’t work but I have a question: why the other icon works correctly?
    thank you
    #1078618
    The icon code you are using does not supported that can be the reason its not showing,
    You can check the icon on font awesome site and choose the icons.
    You are using font-awesome 4.2 version at this time.
    librandi Friend
    #1078635
    Thank you very much,
    I find this <i class="fa fa-bed" aria-hidden="true"> but it doesn’t work
    1. Cattura-1
    #1078643
    Kindly check the screenshot > http://prntscr.com/hitu9e
    it works only for a compatible version.
    You have to download the new version zip and replace it in the template folder
    Take a backup of files before replacing.
    librandi Friend
    #1078661
    thanks, I can’t find 4.3 version download, I find only 4.7 and it doesn’t work
    librandi Friend
    #1078664
    I solved, thank you very much
    #1078966
    You are welcome!
This topic contains 8 replies, has 2 voices, and was last updated by  Pankaj Sharma 7 years ago.
The topic ‘Problem with fa fa-icon’ is closed to new replies.
