mattsh Friend
mattsh
- January 2007
November 27, 2015 at 12:52 pm #758499Hi!
I need some advise how to think and act in my case using Fabrik component and Teline V for Joomla 3.4.5.
From what I understand Joomla itself and Fabrik are using Bootstrap 2 and Teline V template is using Bootstrap 3.The Fabrik component works fine with Joomla until I’m using a Joomlart T3 template like Teline V. Have struggled with the style and made it work. But I still would like to have the ACM-module working to use the Event feature. Sadly it don’t work from the frontend to add event and manage the Event info, because the tabs (Event info and General) are missing. But if I disable the Fabrik system plugin, the Event info tabs are back frontend for event articles.
I think that this is a bit scary and I wonder what other problem I haven’t found yet. What can you tell me make me calmer, since I still want to use the Fabrik component.
MattSaguaros ModeratorSaguaros
November 30, 2015 at 4:00 am #758797Hi Matt,
Did you try to enable the Legacy Compatible mode in General tab of template manager section?
mattsh Friendmattsh
- January 2007
November 30, 2015 at 9:34 am #758834Still the same problem with Legacy Compatible enabled.
December 2, 2015 at 1:25 am #759529Could you PM me URL, admin and FTP account of your site? and also the page where I can see the issue, I will check if I can help something.
mattsh Friendmattsh
- January 2007
December 2, 2015 at 1:58 pm #759836PM sent/Matt
December 4, 2015 at 1:19 am #760464Hi Matt,
I received your PM, kindly also check my PM and also send me the FTP account of your site
mattsh Friendmattsh
- January 2007
December 11, 2015 at 8:35 am #802938Hi Matt,
We just moved to this new system, unfortunately, I couldn’t see PM now, could you please reply again and SET AS PRIVATE reply so that only Moderators and Staffs can see?
mattsh Friendmattsh
- January 2007
December 11, 2015 at 10:04 am #803476This reply has been marked as private.Saguaros ModeratorSaguaros
December 15, 2015 at 1:37 am #813796Hi Matt,
Are you working on your site? I try to go to menu item "create event" but it directs to 403 page.
mattsh Friendmattsh
- January 2007
December 15, 2015 at 7:23 am #814262This reply has been marked as private.Saguaros ModeratorSaguaros
December 15, 2015 at 9:51 am #814484Hi Mat,
I tried to check it but no luck.
Could you please also contact Fabrik’s provider for why this extension prevent these tabs from displaying?
mattsh Friendmattsh
- January 2007
December 21, 2015 at 8:19 pm #827776This reply has been marked as private. -
This topic contains 15 replies, has 2 voices, and was last updated by Saguaros 9 years ago.
