goldorakiller Friend
goldorakiller
- July 2010
- 6 times in 1 posts
August 25, 2010 at 9:32 pm #153817Hello,
1. I’d like to add a cpanel module like ja_lime template to put login module in !
=> Solve ! Disable JA Menu Parameters and re-configure menu2. How can i add a background image ?
=> Solve !
<blockquote>you open the file: /templates/ja_anion/css/template.css and find the following css code:</blockquote>body#bd { background:url(IMAGEPATH); color: #ccc; }
Between becarefull if you use a another theme that default.3. I have problem with image in articles and image from calendar stamp; image from article goes above date ! How solve this ?
=> Solve ! Modify templatre.css line 262 change top value !!!4. How reduce search module ?
5. I have replace the favicon and it doesn’t load ! (I have clean the cache)
Saguaros ModeratorSaguaros
August 27, 2010 at 10:21 am #353856<blockquote>
</blockquote>
you open the file: /templates/ja_anion/css/template.css and find the following css code:body#bd { background-color: #353535; color: #ccc; }
replace:
<blockquote>
</blockquote>
now, you open the file: /templates/ja_anion/css/template.css and find the following code:#ja-search {
background: url(../images/search-bg.png) no-repeat right top;
height: 34px;
width: 290px;
bottom: 10px;
}#ja-search #mod_search_searchword {
background: url(../images/icon-search.png) 99% 4px no-repeat;
border: 0;
width: 246px;
padding: 5px 30px 5px 10px;
margin-top: 3px;
vertical-align: middle;
color: #ababab;
}you adjust the value for the width attribute in both rules. and reduce the width of this image templates/ja_anion/images/search-bg.png
<blockquote>
</blockquote>
you replace this icon: /templates/ja_aninon/images/favicon.ico by yoursgoldorakiller Friendgoldorakiller
- July 2010
August 27, 2010 at 4:38 pm #353885Nobody for help me ?
- 2008 times in 1700 posts
August 28, 2010 at 2:12 am #353915<em>@goldorakiller 191878 wrote:</em><blockquote>Nobody for help me ?</blockquote>
Hi guy,
Tienhc has replied you already. Check again his answer and tell me whether you still get this error or not for further help.
- July 2010
August 28, 2010 at 5:39 pm #353993Sorry JA Developer but when I post Tienhc had not yet responded. :confused:
See hours and date.
I think there a strange way with the forum.
Because if I have see Tienhc reply I didn’t post like this, sorry for the inconvenience :-[
Between thanks for help and for the time you have given meI will go make the modifications and back to tell if this works
PS : for the favicon I have do this but it doesn’t work very strange !! 😎
<blockquote>you replace this icon: /templates/ja_aninon/images/favicon.ico by yours </blockquote>
- July 2010
September 2, 2010 at 11:51 am #354426I still have problem with my favicon.
I have replaced the favicon with my icon but the new favicon is not loaded !
smitheringale Friendsmitheringale
- December 2009
- 44 times in 18 posts
September 2, 2010 at 1:10 pm #354429I’ve decided that the problem with favicons is a problem with the browser itself……
Sometimes, even when I change my favicon, it still won’t show as having changed in the browser for days and sometimes weeks – yet in other browsers the new favicon will show no problem.
I think favicons are just odd little images in a strange format – why can’t people just load a .gif or .jpeg image and have the browser pull off a favicon type image from that – perhaps with a convention that it be called favicon.gif, favicon.jpeg etc. and be placed withn a folder called favicon at the root of the site?
As it is – the way favicons are displayed and presented just seems overly complicated to me – even though with Joomlart templates in theory all you have to do is over-ride the old favicon with your new favicon….but in practice this never seems to be as simple as it sounds…
<em>@goldorakiller 192558 wrote:</em><blockquote>I still have problem with my favicon.
I have replaced the favicon with my icon but the new favicon is not loaded !</blockquote>
bossies Friendbossies
- September 2006
- 16 times in 2 posts
September 4, 2010 at 7:55 am #354593i have the same problem and it’s not cache as i opened the site on a different pc – i want to edit the <head> of my template to add a <link REL=”SHORTCUT ICON” – BUT i no longer have an idea where to do it on this new T2 stuff – could anybody help me to find the <head> of my template?
AuthorPostsViewing 8 posts - 1 through 8 (of 8 total)This topic contains 8 replies, has 5 voices, and was last updated by bossies 14 years, 3 months ago.
Problem with favicon
