  • Giannis Maroulis Friend
    #199783
    Hi all,
    i have a problem with the articles images showing in the “features-1” possition, the two upper articles images are showing correct but the other two dosent feat correctly cause below each of the images are a black space….
    I have make a screenshot, also my website is
    http://www.parathalasso.gr
    Waiting for your advice
    GiannisM
    1. Untitled-1
    Giannis Maroulis
    swissa Friend
    #542830
    Your image – parathal_4_sm.jpg – is too small. The css gives the image space height as 350px and your image is only 300px high.
    Either you can edit the image size or you can edit the css and put this in your custom.css which should solve it.
    .triangle-style .triangle-up .article-img {height: 300px !important;
    Hope that helps!
    #542833
    Thanks a lot worked like a charm 🙂
    Giannis Maroulis
This topic contains 3 replies, has 2 voices, and was last updated by  Giannis Maroulis 10 years, 5 months ago.
