  • creativos2012 Friend
    #172733
    Hello everyone, I’ve installed JA Flowlist on my 1.7.3 new site, in localhost worked perfectly, but when i moved to a host it didn’t work, nothing shows up.
    I thought maybe the quantity of images, but i reduced them to 5 just to try and algo it loads nothing
    The module is in position “user9”
    here’s the site: http://www.balconesdebotavara.com
    Thanks!
    Manos Moderator
    #433610
    Here is a thread that probably will help you solve this issue -> http://www.joomlart.com/forums/topic/flowlist-not-showing-images/
    #433634
    Hi Pascm, thanks for tour answer!
    Before I posted this thread, I searched for a possible solution and I came up with this one you suggest. I opened my helper.php file and tried to do what Khoand said, but my file was different, maybe a new one, so I didn’t try to change it and preferred asking it.
    As you suggested it, I tried to do it, and I think i did it right, a couple of lines above the ones that khoand said, but didn’t work.
    Also I modified content_xml.php as jsnliang said, but didn’t work neither
    Any other suggestions?
    Thanks!
    Manos Moderator
    #433665
    Hi can you please provide me with a temp super admin access and ftp (via PM) so i can investigate this further for you?
    #433865
    I sent you a PM 🙂
    #434286
    any idea? ..
    Manos Moderator
    #436392
    I am sorry but i tried everything i knew and it didn’t work i will ask some help from my colleagues can you please provide me with ftp details also so we can try to find a better solution that works ?
    #438739
    Hello Pascm, sorry for the late response, i’ve had some personal problems and i couln’t answer, i’m sending you in a PM the information
    Thanks!
    Manos Moderator
    #439522
    Sure no problem, i have replied to your PM asking for Super Admin access so we can proceed to solve your issue!
    #440809
    <em>@creativos2012 294372 wrote:</em><blockquote>Hello everyone, I’ve installed JA Flowlist on my 1.7.3 new site, in localhost worked perfectly, but when i moved to a host it didn’t work, nothing shows up.
    Thanks!</blockquote>
    Hi creativos2012,
    your module is not latest version, i just updated it for you and now it worked, you can check it again !
    #443987
    <em>@Dat Hoang 303827 wrote:</em><blockquote>Hi creativos2012,
    your module is not latest version, i just updated it for you and now it worked, you can check it again !</blockquote>
    Thank you very much!
    Manos Moderator
    #443988
    Hello creativos2012,
    Is everything ok now on your website ? I just visited your web page and JA Flowlist seems to be working as it should.
    Please let me know if there is anything else you need help with.
    #444093
    Yes, it’s everything ok for now, thank you very much!
This topic contains 13 replies, has 3 voices, and was last updated by  creativos2012 12 years, 9 months ago.
