Viewing 15 posts - 1 through 15 (of 41 total)
  • brucect Friend
    #187501
    When a module enabled in footer-5 or footer-6, footer module is float right. Is there a bug ?
    also search dont show up head-search module. what is wrong?
    1. Capture1
    2. Capture
    TomC Moderator
    #492728
    What is it that you are trying/wanting to accomplish with the module in your footer?
    brucect Friend
    #492748
    thanks tom.
    see the screenshot dont you see the bottom footer float right. it s not in the same size with the body. footer-5 and footer-6 modules making span.
    search module just dont show up at the template suggested place head-search.
    I am trying to accomplish is similar look with suggested at the demo
    http://www.joomlart.com/forums/topic/ja-hawkstore-userguide/
    these are bugs with the template and needs to be fix
    Hi brucect,
    I try to add a new module to footer-5 and footer-6 like articles most read as this screenshot:
    I see the footer looks as normal
    brucect Friend
    #492827
    are you running joomla core 3.1.1 with php 5.4? and template version 1.0.0?
    please make sure you install template from downloaded source and and use it.
    let me know please
    thanks
    Template Information
    Name:
    Ja Hawkstore
    Version:
    1.0.0
    Released Date:
    11 May 2013
    Author:
    JoomlArt.com
    System Information
    Setting Value
    PHP Built On Linux host190.hostmonster.com 2.6.32-20130307.60.9.bh6.x86_64 #1 SMP Thu Mar 7 15:58:33 EST 2013 x86_64
    Database Version 5.5.31-log
    Database Collation utf8_general_ci
    PHP Version 5.4.13
    Web Server Apache
    WebServer to PHP Interface cgi-fcgi
    Joomla! Version Joomla! 3.1.1 Stable [ Ember ] 26-April-2013 14:00 GMT
    Joomla! Platform Version Joomla Platform 12.2.0 Stable [ Neil Armstrong ] 21-September-2012 00:00 GMT
    User Agent Mozilla/5.0 (Windows NT 6.1; WOW64; rv:21.0) Gecko/20100101 Firefox/21.0
    brucect Friend
    #492834
    I have a 2.5 install . I have tried there seems like footer fine there but search module still dont show up at head-search position.
    I have looked at the header.php file there is no mention about head-search .
    so this is definitely Joomla 3 related. but head-search dont work at all.
    Thanks for your help.
    PHP Version 5.4.13
    Web Server Apache
    Joomla! Version Joomla! 2.5.11 Stable [ Ember ] 26-April-2013 14:00 GMT
    Joomla! Platform Version Joomla Platform 11.4.0 Stable [ Brian Kernighan ] 03-Jan-2012 00:00 GMT
    brucect Friend
    #492892
    I think I gotta open a ticket. looks like no help in forum
    Hi brucect,
    Due to concept of this template, the search module will be assigned to menu item named ‘Search’. If you want it looks like demo, you can create a new menu item with this backend settings: http://static.joomlart.com/images/userguide/ja_templates/ja_hawkstore/search-menu.png
    Then create a search module, assign it to head-search position: http://static.joomlart.com/images/userguide/ja_templates/ja_hawkstore/search-backend.png
    In template manager > Navigation tab > you need to assign above search module to search menu item:
    See our user guide for more information: http://www.joomlart.com/forums/topic/ja-hawkstore-userguide/
    Hope you got the idea.
    brucect Friend
    #492905
    Thanks for the reply. guide is confusing with search module. it does not clarify is it extra created in mega menu or it comes as internal
    module. that’s why i did not look at the menu section of the guide.
    how about footer 5-6 makes footer module float right on the joomla 3?
    you got anything on that?
    I tested again but the result is the same with my previous reply, these module in footer position still dispaly fine:
    brucect Friend
    #492928
    what is the joomla version are u using in this screenshot
    thanks
    I test in my local with Joomla v 3.1.1 stable version > install T3 plugin + template > then add some modules as screenshot.
    Is your site online? PM me admin and FTP account of your site, I will check this for you.
    brucect Friend
    #492941
    its a test site but i will reinstall joomla and test again.i will post results here. I was playing so much with LESS files I got maybe something messed up.
    thanks
    Let me know if you still experience this problem then 🙂
    BTW, this JA Hawkstore uses Virtuemart component which, however, doesn’t support Joomla 3 at this moment. Hence this template runs well with Joomla 2.5 only. Version for Joomla 3.0 will be released when Virtuemart component is available for Joomla 3.0
    See more in this info page: http://www.joomlart.com/joomla/templates/ja-hawkstore
    Best Regards
This topic contains 41 replies, has 4 voices, and was last updated by  mahdiit 11 years, 3 months ago.
