Viewing 15 posts - 16 through 30 (of 41 total)
  • brucect Friend
    #494102
    I have a fresh install joomla 3 problem solved
    thanks
    mahdiit Friend
    #503516
    <em>@Saguaros 372932 wrote:</em><blockquote>Hi brucect,
    Due to concept of this template, the search module will be assigned to menu item named ‘Search’. If you want it looks like demo, you can create a new menu item with this backend settings: http://static.joomlart.com/images/userguide/ja_templates/ja_hawkstore/search-menu.png
    Then create a search module, assign it to head-search position: http://static.joomlart.com/images/userguide/ja_templates/ja_hawkstore/search-backend.png
    In template manager > Navigation tab > you need to assign above search module to search menu item:
    See our user guide for more information: http://www.joomlart.com/forums/topic/ja-hawkstore-userguide/
    Hope you got the idea.
    Regards</blockquote>
    Hi Saguaros
    I have the same problem and I follow your reply but I can not solve it.
    You can pm me an admin account of your site, I will check it for you 🙂
    mahdiit Friend
    #503560
    <em>@Saguaros 386582 wrote:</em><blockquote>You can pm me an admin account of your site, I will check it for you :)</blockquote>
    I sent you my admin information Saguaros.
    Hi mahdiit,
    I added the search module in search menu item in your site for you, kindly take a look 🙂
    For the tab display products in homepage, did you installed any 3rd party extensions in your site?
    Also check the permission of files/folder of your site in your server is correct (file- 644 and folder- 755)
    mahdiit Friend
    #503661
    <em>@Saguaros 386740 wrote:</em><blockquote>Hi mahdiit,
    Also check the permission of files/folder of your site in your server is correct (file- 644 and folder- 755)</blockquote>
    Hi Saguaros
    thank you for your helping. search module solved.
    About 3rd party extensions, I installed all required plugins, components and modules in my server just like quick start.
    About permission, I checked it and it was true and my website displays products but not like Demo.
    Please visit http://www.kowsartheme.com
    Hi mahdiit,
    It seems to work fine now, right? http://www.kowsartheme.com/
    Let me know if you still need helps.
    mahdiit Friend
    #503844
    <em>@Saguaros 386988 wrote:</em><blockquote>Hi mahdiit,
    Let me know if you still need helps.</blockquote>
    Hi Saguaros
    Thank you.
    Yes my site works fine now Realy, but a small problem is now in home-1, because my products pictures are a bit large than required.
    there should be 4 pictures but my website displays 3 pictures.
    1. screenkowsar
    Kindly check your site again, it seems that your account in hosting was suspended. 🙂
    mahdiit Friend
    #503892
    <em>@Saguaros 387037 wrote:</em><blockquote>Kindly check your site again, it seems that your account in hosting was suspended. :)</blockquote>
    Oh new problem. my data center suspended my host. they believe that a file in my library folder named as mailer.php and some file like this sent spam to them and suspending was an alert. whats your idea? how can I solve that?
    You should contact your hosting to find out the best solution, sorry for not be of much help in this case.
    mahdiit Friend
    #504437
    <em>@Saguaros 387714 wrote:</em><blockquote>Hi
    You should contact your hosting to find out the best solution, sorry for not be of much help in this case.</blockquote>
    Hi Saguaros
    Could you please tell me why my home-1 position shows 3 items instead of 4 items?
    thanks
    1. bug
    Did you make any change to your site? I cannot access backend of your site, it gave 500 error, kindly check again.
    mahdiit Friend
    #504852
    <em>@Saguaros 388259 wrote:</em><blockquote>Did you make any change to your site? I cannot access backend of your site, it gave 500 error, kindly check again.</blockquote>
    Hi Saguaros
    I sent you a new username and password as a pm.
    I also have a problem in the Cart. when new product added to Cart I should refresh web page to updating it.
    thanks.
    Hi mahdiit,
    The problem comes from JA Tabs plugins in RTL language, we fixed this issue and I’ve updated this plugin for you. It seems to be working now, kindly have a look at this.
This topic contains 41 replies, has 4 voices, and was last updated by  mahdiit 11 years, 3 months ago.
