Viewing 11 posts - 31 through 41 (of 41 total)
  • mahdiit Friend
    #505607
    <em>@Saguaros 389165 wrote:</em><blockquote>Hi mahdiit,
    The problem comes from JA Tabs plugins in RTL language, we fixed this issue and I’ve updated this plugin for you. It seems to be working now, kindly have a look at this.
    Regards</blockquote>
    Hi Saguaros
    Thank you for your helping.
    Please take a look at my Cart. The product number not updated in cart.
    Could you also pm me ftp account of your site for further checking?
    mahdiit Friend
    #505933
    <em>@Saguaros 389341 wrote:</em><blockquote>Could you also pm me ftp account of your site for further checking?</blockquote>
    Could you please solve my Cart problem I sent you my information as a pm 3 days ago.
    Thank you.
    Dear mahdiit,
    The problem comes from this plugin in your site: VMPAYMENT_MELLAT_JOOMINA_IR, I just disabled it and the add to cart funtion updating the number of product works fine now.
    You should try to contact the provider of this plugin to check it for you.
    mahdiit Friend
    #506367
    <em>@Saguaros 390183 wrote:</em><blockquote>Dear mahdiit,
    Thank you Saguaros
    But the provider of this plugin cant solve it?
    Please solve it if you can Saguaros.
    Thanks.
    We don’t have right to make change in 3rd party extension, you may take a look at this file: /public_html/plugins/vmpayment/vmmellat/vmmellat.php and change in JS code.
    mahdiit Friend
    #506448
    <em>@Saguaros 390341 wrote:</em><blockquote>Hi
    We don’t have right to make change in 3rd party extension, you may take a look at this file: /public_html/plugins/vmpayment/vmmellat/vmmellat.php and change in JS code.</blockquote>
    Hi Saguaros
    Thanks for your attention. but this extension is free.
    mahdiit Friend
    #506855
    Hi Saguaros
    I sent a pm to you about my cart and I am waiting for you.
    Thanks.
    <blockquote>
    Hi Saguaros
    If after adding a product to Cart, page will automatically be refreshed, Cart updating problem will be solve.
    could you please do it.
    </blockquote>
    Could you tell me more details about problem here?
    mahdiit Friend
    #507038
    <em>@Saguaros 391055 wrote:</em><blockquote>Could you tell me more details about problem here?</blockquote>
    Hi Saguaros
    You’ve asked for more information about my Cart problem.
    My Cart is not updated when adding a product, but the Cart is being updated after refresh the page. you said that problem is in my Paymentmellat plugin, but I can not change my Paymentmellat plugin.
    solution: If the page to be refreshed after adding the product to Cart automatically, The problem will be solved.
    For example: when customer clicks on the “add to cart” (im my language “خرید”) button, the page to be refreshed.
    mahdiit Friend
    #507428
    Thank you for your help.
    I solved it.
This topic contains 41 replies, has 4 voices, and was last updated by  mahdiit 11 years, 3 months ago.
