marco17 Friend
marco17
- January 2009
- 3 times in 2 posts
November 22, 2016 at 12:03 pm #988581Hi, we have a problem with the frontend (backend woks ok). http://www.hispalusamascotas.com
The error log says:
[22-Nov-2016 11:57:36 UTC] PHP Parse error: syntax error, unexpected ”to’ (T_ENCAPSED_AND_WHITESPACE) in /home/hispalusa/public_html/plugins/system/t3/includes/menu/megamenu.tpl.php on line 257
Before the error log says:
[22-Nov-2016 11:12:57 UTC] PHP Fatal error: Cannot redeclare virtuemartBuildRoute() (previously declared in /home/hispalusa/public_html/components/com_tcpdf/router.php:23) in /home/hispalusa/public_html/components/com_virtuemart/router.php on line 332
We have unistalled virtuemart and now is still no working.
I attach the eror log in case can help you to understand the problem.
Many thanks.
Marco
- November 2014
- 3854 times in 3563 posts
November 23, 2016 at 1:29 am #988797Hi,
Have you sorted out it? I check on your site but I could not see the problem on your site. If you still need to help please send me the link to see this bug and admin login via private reply. I will detect it for you.
marco17 Friendmarco17
- January 2009
November 23, 2016 at 7:44 am #988892This reply has been marked as private.marco17 Friendmarco17
- January 2009
November 23, 2016 at 12:56 pm #988990Hi, i have just installed a new joomla with Megastore template. It is installed with 3.5.1 version.
When i did the upgrade (just after installing) to 3.6.4 the problem came.
I think there is some problem with the upgrade.
Marco
- November 2014
November 24, 2016 at 7:28 am #989223This reply has been marked as private.marco17 Friendmarco17
- January 2009
November 25, 2016 at 9:05 am #989647Sorry Ninja,
I forgot give you the super user set…..
My apologize.
Try now please.
Thanks.
Marco
- January 2009
November 27, 2016 at 4:25 pm #990085Hi, i have tried to unistall VM but now the website is showed with the basic joomla tempalte.
I have installed again VM and the errror is showed again.
Marco
- January 2009
November 27, 2016 at 9:02 pm #990133This reply has been marked as private.Ninja Lead ModeratorNinja Lead
- November 2014
November 28, 2016 at 1:16 am #990157This reply has been marked as private.marco17 Friendmarco17
- January 2009
December 1, 2016 at 8:33 am #991521This reply has been marked as private.Ninja Lead ModeratorNinja Lead
- November 2014
December 2, 2016 at 5:22 am #991698Hi,
I could not access backend and FTP account of your site with the credential info above http://prntscr.com/dec0vs and http://prntscr.com/dec30u
But you can try to use this way
rename the folder /components/com_tcpdf/ to /components/com_tcpdf___/
The issue seems from tcpdf and Joomla .
You can also download latest version of tcpdf and install it on your site .Hope it helps
- January 2009
December 7, 2016 at 9:08 am #992853This reply has been marked as private.Ninja Lead ModeratorNinja Lead
- November 2014
December 8, 2016 at 1:43 am #993049Hi,
It’s very strange with your hosting. I could not access the backend of your site at my end: http://prntscr.com/dgpi9w
Besides this bug does not come from our product, you can submit your request to Virturemart forum, you will get the best answer from them
This topic contains 12 replies, has 2 voices, and was last updated by Ninja Lead 7 years, 9 months ago.
