  • b4nite Friend
    #160376
    What I do:
    1. I do a fresh install, with the quicksetup package for Joomla 1.6.
    2. I updated ja-slideshow to 1.0.4 (the older one 1.0.2 has a bug) <- Actually no need to show the problem)
    3. I click on a featured article (the ones that is under: Welcome to the frontpage).
    4. The article shows up together with all the frontpage modules <– my problem.
    This is not a behaviour on the demo (J 1.5, and also on my 1.5 installs).
    I usually use quicksetup for new sites, and don’t know if its recommended if you want most of the functionality as in the demo.
    Tried JA-Rasite too (another favourite of mine), same result with featured articles directly from the quickinstall.
    Any suggestion welcome, my ideas start to run out.
    -André
    #378028
    Dear b4nite,
    If you want those articles display without modules around it, you just need to create a menu item that refer to that article or refer to the category which the article belong to then don’t assign modules for this menu item.
    It is just a setting issue and you can do it yourself.
This topic contains 2 replies, has 2 voices, and was last updated by  Sherlock 13 years, 10 months ago.
