  • hearts Friend
    #126702
    Here is our website: http://www.hearts-at-home.org.
    Works great in IE7.
    However, in IE6, the user appears to have problems with our forms.
    The user cannot answer our polls: http://www.hearts-at-home.org/index.php?option=com_frontpage&Itemid=103
    The user cannot complete our feedback form: http://www.hearts-at-home.org/index.php?option=com_content&task=view&id=26&Itemid=88
    What is the solution for the IE6 user to be able to click and enter on our forms, polls, etc. They cannot click on the radio button or in the boxes on the form
    Please advise. We need an answer very quickly as we will be having many, many users fill out our feedback form in the next two days.
    Thanks for your help! We are very happy with our template and the look of our new website!!!
    Menalto Friend
    #242502
    i just checked and it works fine here in IE6 the form, but the Poll didnt work, can you try to put the poll module in the right top position?
    tegs Friend
    #249695
    I have had feedback that IE 6 does not work either.
    The links in the main body of the site do not work. I have checked on several PC’s and this problem is not consistent, however the feedback that I have received is that on smaller monitors (15″ or less) the links do not work when using IE6.
    I was sceptical but when I loaded IE6 on my laptop and tested it I could recreate the problem, if I then plugged in my 19″ monitor all worked fine.
    tegs Friend
    #249989
    cwigg solved my links issue in IE6 with the following advice:
    BUG – If you links are not linkable in IE, then make these changes
    add
    position: relative;
    to lines 68 (normal link) and 171 (.inputbox) in template_css.css
    there may be other elements that need the position relative attribute.
    You may want to give it a go!
This topic contains 4 replies, has 3 voices, and was last updated by  tegs 16 years, 7 months ago.
