  • imurillo Friend
    #144456
    Hi friends, I have a problem that I need to resolve as a matter of urgency,
    I changed these parameters in global configuration :
    Allow user registration = no
    Enable accounts for users = NO
    Parameters for home users = hide
    After I did These changes I cannot return to Backend Administrator page and Frontend page public, I need somebody tell me how to set these parameters to as they were initially.
    I only watch a blank screen with a message
    Internet Explorer cannot display the webpage
    Thank you
    Isabel
    bennitos Friend
    #318032
    Hello Isabel,
    I dont think that the parameters you mentioned above have caused this problem.
    If you need help solving this problem we need to have some more information to be able to help you.
    Please edit your first post, click on the go advanced button and select YES (Require Help From Staff + Mod/Admin: ) Put the information about your site there only mods and JA staff will be able to see that information.
    With that information we can actually have a look to help you sort this out.
    With Regards,
    imurillo Friend
    #318036
    I only changed these parameters
    The problem after I change is
    The site urls is : http//sgerencia.cancilleria.gob.ni
    but explorer and firefox change by https//sgerencia.cancilleria.gob.ni
    Tellme how I deactivate https in joomla.
    bennitos Friend
    #318040
    Hello Isabel,
    The url you posted does not work.
    imurillo Friend
    #318267
    Thank you for your quick response, the problem was already resolved,
    When I installed the template JAraite I donĀ“t know why SSL mode was activated
    The page not loaded by the https without certificate mode
    I changed var $ force_ssl = ‘2’
    by
    $ force_ssl = ‘0’ and the web page load.
This topic contains 5 replies, has 2 voices, and was last updated by  imurillo 15 years, 3 months ago.
