  • mjrsanders Friend
    #142429
    I have a little problem with the header colors in ja zeolite.
    I have attached a link to a picture of the problem.
    1. In firefox 3 and ie 7 the header turn blue around the icon for the shopping cart.
    2. I went through the code and found that the RGB colors have to be changed from 0,90,135 too 255,255,255.
    Anyone have a suggestion as to where to change this?
    Best,
    Marc
    bossies Friend
    #347852
    any answer as i have the same problem when changing my header to white
    #347940
    <em>@bossies 183841 wrote:</em><blockquote>any answer as i have the same problem when changing my header to white</blockquote>
    Hi bossies,
    Could you please posting your url in here,I would like to have a closer look at the issue !
    bossies Friend
    #347943
    http://www.amberstone.co.za
    thanks – its when you go to the shop and add a item – it basically creates a effect to show your cart – it does go away when you refresh
This topic contains 4 replies, has 3 voices, and was last updated by  bossies 14 years, 6 months ago.
