Tech-xml Friend
Tech-xml
- October 2010
- 5 times in 2 posts
December 10, 2015 at 6:50 pm #797183Problem with header Kunena
The header Kunena is not being fully displayed.Note.
In presenting the solution, please see if it does not create a problem with the video module on the home page (generating a spacing between the module and the main menu).
Saguaros ModeratorSaguaros
December 11, 2015 at 3:55 am #800977Hi @Tech-xml,
You can try with this tweak:
- Open the file: root/templates/uber (your default template)/css/custom.css (create this file if it doesn’t exist)
- Add this rule:
.com_kunena .t3-mainbody { padding-top: 30px; }
AuthorPostsViewing 2 posts - 1 through 2 (of 2 total)This topic contains 2 replies, has 2 voices, and was last updated by Saguaros 9 years ago.
