August 15, 2011 at 1:55 pm #167435
Hi!
I’m working on a project with JA Pyro’s template and I have done several changes on the header. The visualization looks fine if you see the site with zoom 100%. The problem is that if zoom in or out, the header does no fit the rest of the content. I think this might be fixed with some CSS code, but I need some help. Any idea?
Thanks in advance!
pritam Friendpritam
- April 2011
- 125 times in 113 posts
August 16, 2011 at 7:11 am #406476Hello benteveo ,
To Problem with Header when changing zoom
Find this code to /templates/ja_pyro/css/template.css line no.1152
#ja-header {
background-color: #ECEEEB;
border-left-color-ltr-source: physical;
border-left-color-rtl-source: physical;
border-left-color-value: #626262;
border-left-style-ltr-source: physical;
border-left-style-rtl-source: physical;
border-left-style-value: solid;
border-left-width-ltr-source: physical;
border-left-width-rtl-source: physical;
border-left-width-value: 2px;
border-right-color-ltr-source: physical;
border-right-color-rtl-source: physical;
border-right-color-value: #626262;
border-right-style-ltr-source: physical;
border-right-style-rtl-source: physical;
border-right-style-value: solid;
border-right-width-ltr-source: physical;
border-right-width-rtl-source: physical;
border-right-width-value: 2px;
line-height: normal;
margin-bottom: -2px;
margin-left: 351px;
margin-right: 0;
margin-top: -37px;
padding-bottom: 0;
padding-left: 0;
padding-right: 0;
padding-top: 0;
position: relative;
width: 957px;
z-index: 10;
}Change this code to :-
#ja-header {
margin-left: 351px;
margin-right: 0;
margin-top: -37px;
padding-bottom: 0;
padding-left: 0;
padding-right: 0;
padding-top: 0;
position: relative;
width: 957px;
z-index: 10;
right:198px;/*set pixel as per reqiurement*/
}Val Kupstas FriendVal Kupstas
- August 2011
- 5 times in 5 posts
August 16, 2011 at 7:26 am #406479The best would be to change this line here:
margin: -37px 0 -2px 351px;
Into this here:
margin: -37px auto -2px auto;
And DO NOT add the right:198px;/*set pixel as per reqiurement*/
As the solution above with add right:198px; would need to be adjusted pr screen resolution and will not work out in the long run.
1 user says Thank You to Val Kupstas for this useful post
This topic contains 4 replies, has 3 voices, and was last updated by benteveo 13 years, 4 months ago.
