  • davilico Friend
    #200229
    We have a problem in slideshow lite module with the height of the images. Some of them does not fill thee height of the div… All have the same height…..
    Thanks.
    Pankaj Sharma Moderator
    #544436
    Yes the images are comes after resized folder .
    Module cached the images in images/resized folder .
    and images are resized in size to maintain the ratio of images for frontend display .
    There you can see all the images are of same size .
    you can also see the option in JA slideshow module settings >>> http://prntscr.com/49fhfn
    Hope it helps
This topic contains 2 replies, has 2 voices, and was last updated by  Pankaj Sharma 10 years, 2 months ago.
