  • dustinwivell Friend
    #1009369
    I have previously used this on this site and had no problems but now when I try to update it the formatting and shapes disappear and it is shrunken down. I can’t figure out what went wrong all of a sudden it just stopped working.
    1. 2017-02-09
    Did you try to remove this block and add it again?
    If it doesn’t work, share me the login info of your site, I will take a look.
    dustinwivell Friend
    #1009443
    Hi Dustin,
    As I can see that the format / shape of this block still looks good as the default: http://prntscr.com/e6uv9w
    Could you illustrate how it should be via screenshots?
    dustinwivell Friend
    #1009459
    Hello Saguaros,
    It looks correct before I publish it but when I publish it the box and format are gone like in the before and after shots attached
    Thank you
    1. before
    2. after
    dustinwivell Friend
    #1009462
    I just noticed that it only happens when I edit with Chrome browser but works fine in Internet Explorer.
    Thank you
    I just tried to edit the text and publish but all are still there.
    Could you check again?
    dustinwivell Friend
    #1009495
    Seems is a problem only in certain browsers. Error happens in google chrome browser but not in Internet Explorer
    Thank you for all your hlep
    You’re welcome!
    Let us know if you need any further helps.
    Have a nice day!!!
This topic contains 8 replies, has 2 voices, and was last updated by  Saguaros 7 years, 9 months ago.
