January 28, 2014 at 6:41 pm #194207
Hello.
We faced with the problem.
In the latest version of T3 and Megamenu:
1. Hidden classes don’t work in front-end
2. Mega-menu shifts to the left in the responsive versions.We found this from version 2.0 and now it’s still present. Could you check please.
Thanks in advance.Wall Crasher DeveloperWall Crasher
- December 2011
- 361 times in 300 posts
January 31, 2014 at 7:02 am #520616@ velikorodnov,
Please make sure you recompile LESS to CSS. Also, check if your LESS file include a core LESS: pluginsystemt3baselessgrid-ext-responsive.less
For the second issue, please capture a screenshot, I will help to debug.
February 3, 2014 at 8:38 pm #521008Hello. Thanks for the first question. I will check.
About second – attach the image. When I use the responsive menu move left
Thanks in advance
- December 2011
February 4, 2014 at 2:37 am #521035Hi velikorodnov,
Can you please re-upload the attach file? A link to 3rd hosting is fine.
Also, I do not think there is a problem with the menu. Did you try to have it center-aligned?
The menu will try to re-align so that the submenu is visible and not cut-off by browser screen.February 4, 2014 at 9:45 pm #521181Wall Crasher DeveloperWall Crasher
- December 2011
February 6, 2014 at 3:21 am #521410@ velikorodnov,
As I said above, we have a small script that re-aligns the menu so that the submenu is not hidden by browser. I do not think it is a bug.
AuthorPostsViewing 6 posts - 1 through 6 (of 6 total)This topic contains 6 replies, has 2 voices, and was last updated by Wall Crasher 10 years, 9 months ago.
