March 27, 2007 at 3:33 pm #119388
I am having a little trouble with the highlight module. I changed the psd file for the background of the blue module and now the module displays more narrow than the titlebar of the module (see attached image). I have verified that the file is the same size as the original file in the /images/blue folder. Please help me get this fixed.
Here is the code that is in the module. It is a custom user module I created.
<!-- Begin HL Code - http://www.heartlight.org --> <table width="100%" cellspacing="0" cellpadding="0" border="4"><tbody><tr><td><font ace="Arial, Helvetica, sans-serif"><script src="http://www.heartlight.org/hls/tv_niv.js"></script></font></td></tr></tbody></table><!-- End HL Code - http://www.heartlight.org -->
ShannonN FriendShannonN
- July 2006
- 172 times in 49 posts
March 27, 2007 at 4:00 pm #216597whouse;10941I am having a little trouble with the highlight module. I changed the psd file for the background of the blue module and now the module displays more narrow than the titlebar of the module (see attached image). I have verified that the file is the same size as the original file in the /images/blue folder. Please help me get this fixed.
Refresh the browser cache and try again
often this happens to me after i change the modules or add a suffix to colour them a refresh redraws them from scratch and bypasses the cached image
ShannonN
March 27, 2007 at 6:07 pm #216617ShannonN,
Thanks for the reply but that didn’t change anything. The module is still askew. It’s funny that when I change the module to not show the title, it is still displayed the same way. The title is no longer above the module but the background is smaller at the bottom than it is at the top.
I don’t know if my first post was clear so just in case, I’ll clarify it here. I edited the source file box-hilite-bk.gif and removed the image at the bottom (the xenia logo image) and replaced it with a layer of my own and saved it. I used photoshop to do this so there shouldn’t be any kind of issue with the editor since it is the same as the devs use.If you would like to have a look, go here: http://www.glorywalk.org
Any help is appreciated.
Thanks.
Hung Dinh FriendHung Dinh
- 3310 times in 3 posts
March 27, 2007 at 6:27 pm #216622Do you have the live URL, whouse?
March 27, 2007 at 6:40 pm #216627<em>@Hung Dinh 10971 wrote:</em><blockquote>Do you have the live URL, whouse?</blockquote>
Yes. I am sorry. I edited the post, most likely while you were reading it.
The URL is http://www.glorywalk.org
Thanks Hung!
Khanh Le ModeratorKhanh Le
- November 2013
- 203 times in 131 posts
March 28, 2007 at 4:09 am #216656Whouse, the difference in your new background image: templates/ja_xenia/images/blue/box-hilite-br.gif. The white space around your new backgound image is bigger than the default image.
March 28, 2007 at 4:37 am #216657<em>@Khanh Le 11024 wrote:</em><blockquote>Whouse, the difference in your new background image: templates/ja_xenia/images/blue/box-hilite-br.gif. The white space around your new backgound image is bigger than the default image.</blockquote>
I’ll take a look at it. I don’t understand how that could have happened since I used the psd source file supplied in the xenia source zip. Once I have looked at the images and compared them, I will report back here whether I have managed to fix it or not.
Thanks Khanh Le for the reply.
EDIT: I was able to fix it using the original file from the template image directory and erase the image in the lower right corner and replace it with my own image. Not sure exactly what the problem was with the image in the source file zip I downloaded but I got it fixed. Thanks to everyone that replied. I greatly appreciate it.
I am removing the “NOT SOLVED” from the title as this is done.
Thanks,
WayneAuthorPostsViewing 7 posts - 1 through 7 (of 7 total)This topic contains 7 replies, has 4 voices, and was last updated by whouse 17 years, 9 months ago.
Problem with highlight module
