  • gozal Friend
    #128158
    hi,
    if i click on login, sign up or search on ie7, it shows the pop up 1 sec and redirect to the login, sign up or search page.
    Works fine with firefox.
    The version installed is the quickstart.
    Thanks for your help.
    Patrick
    Menalto Friend
    #269326
    Did you manage to get this solved? If you did please mark this as solved, in not reply here and we will try to help you out.
This topic contains 2 replies, has 2 voices, and was last updated by  Menalto 16 years, 4 months ago.
