January 4, 2012 at 7:32 am #172410
Hi guys,
My site url is http://affiliateclubhouse.com
But my template is not working only on the home page and after i will click on my any link,then it works fine or even if it works on http://affiliateclubhouse.com/index.php perfectly…
So please please tell me how to fix this problem.I hv attcahed the screen so can easily understand the prob…
January 4, 2012 at 7:35 am #432433Hi
Have you renamed your htaccess.txt in .htaccess ?
January 4, 2012 at 7:41 am #432435No I haven’t change with .htaccess file..
pavit Moderatorpavit
January 4, 2012 at 7:54 am #432436Now i can see your home correctly showed
January 4, 2012 at 10:05 am #432459Yes,you can see actually i want to change my contact us page,when i change in the code of contact page the address of file is components/com_contact/views/contact/tmpl/default_form.php it will look like as i have mentioned in the question and if i doesn’t make any changes in default_form.php as previous one it works smoothly …
Do you know why its happening ??Any help and suggestions is appreciated, thank you.
Viewing 5 posts - 1 through 5 (of 5 total)This topic contains 5 replies, has 2 voices, and was last updated by amit_s_r 12 years, 11 months ago.
