Viewing 6 posts - 16 through 21 (of 21 total)
  • garciad Friend
    #264254
    <em>@nguoiabcd 72101 wrote:</em><blockquote>Hi garciad
    Your module is old version (I checked via FTP what you send me at other topic via PM)
    i changed for you mod_ja_catslwi.php (modulesmod_ja_catslwi)
    Change from:
    JHTML::stylesheet( "ja_catslwi.css","/modules/mod_ja_catslwi/mod_ja_catslwi/");
    To
    JHTML::stylesheet('',modJaSLWI::getFile('ja_catslwi.css','modules/mod_ja_catslwi/mod_ja_catslwi/','templates/'.$mainframe->getTemplate().'/css/'));
    </blockquote>
    OK, that’s means that I don’t have to unistall and install again the module… I am right?
    Thanks a lot!
    Gue.
    #264255
    Yes, you dont need to reinstall, but i think you should often update version of extensions and template
    jensl Friend
    #264952
    I’ve got this problem as well, but this solution doesn’t help me. I haven’t got this reference:
    <link type=”text/css” href=”/modules/mod_ja_catslwi/mod_ja_catslwi/ja_catslwi.css” rel=”stylesheet”>
    anywhere in the entire site.
    Best regards
    Jens
    #264965
    Hi Jensl .
    Plz read my posts above
    jensl Friend
    #264996
    Thanks a mill. Now it woks! It’s incredible what one finds if one cares to open both eyes 🙂
    Best regards
    Jens
    chopperp1 Friend
    #265613
    I’ve got another flavor of the problem in this mod…
    All shows up as designed except pictures. I’ve verified the code, user guide and all seems to be in place. Resizing of images works fine, so I don’t think that’s the issue with my host. I have clean install of Joomla 1.5.6 on hostmonster.com…
    Any clues?
    Big thanks in advance….
This topic contains 21 replies, has 8 voices, and was last updated by  chopperp1 16 years, 4 months ago.
