Tech-xml Friend
Tech-xml
- October 2010
- 5 times in 2 posts
June 16, 2015 at 12:44 pm #207454Pankaj Sharma ModeratorPankaj Sharma
June 16, 2015 at 3:04 pm #574250Hello
Try the solution given below
Add this code in custom.css file.t3-header {
z-index: 25!important; }
Clear cache and check.
Tech-xml FriendTech-xml
- October 2010
June 16, 2015 at 5:38 pm #574268@pankajsharma Not solved, also cleaned the cache
- October 2010
June 16, 2015 at 5:38 pm #640602@pankajsharma Not solved, also cleaned the cache
- October 2010
June 16, 2015 at 5:38 pm #739277@pankajsharma Not solved, also cleaned the cache
June 17, 2015 at 12:17 am #574322<em>@insofticursos 478432 wrote:</em><blockquote>@pankajsharma Not solved, also cleaned the cache</blockquote>
Hello i saw there is syntax error in code .
you have added dot . Before t3 header code in custom.css
please apply the right code and check it again.Pankaj Sharma ModeratorPankaj Sharma
June 17, 2015 at 12:17 am #640661<em>@insofticursos 478432 wrote:</em><blockquote>@pankajsharma Not solved, also cleaned the cache</blockquote>
June 17, 2015 at 12:17 am #739331<em>@insofticursos 478432 wrote:</em><blockquote>@pankajsharma Not solved, also cleaned the cache</blockquote>
please apply the right code and check it again.Tech-xml FriendTech-xml
- October 2010
June 17, 2015 at 12:36 am #574323It is true! Sorry. Now everything is settled. thank you
- October 2010
June 17, 2015 at 12:36 am #640662It is true! Sorry. Now everything is settled. thank you
- October 2010
June 17, 2015 at 12:36 am #739332It is true! Sorry. Now everything is settled. thank you
AuthorPostsViewing 11 posts - 1 through 11 (of 11 total)This topic contains 11 replies, has 2 voices, and was last updated by Tech-xml 9 years, 4 months ago.
Problem with icons over mainmenu
