  • charala Friend
    #117416
    Hi , when i view the template in IE the right modules move downwards and begin where my text in the main body ends.
    In mozzila i dont have any problem.
    This happens only when i view the template in narrow mode in IE , in wide i dont have a problem in IE to.
    Any help on that?
    Thanks in advance.
    mark pemberton Friend
    #211143
    Which IE version are you using? Mark
    Boanerg Friend
    #211150
    I do have the same problem.
    Right Colum starts where Centertext ends.
    Opera and Firefox are showing OK.
    IE Version 6.0.2900.2180.xpsp_sp2gdr.050301-1519
    Testserver is at http://www.music-event-page.de/web
    Thanks for your help
    Buster Friend
    #211161
    it may be that one or more of your content items is too wide. Try unpublishing all content and then republishing each one until you find the problem. An alternative would be to unpublish the right hand modules to determine if the problem is there and not the content.
    Because the right hand module header appears to overlap the content then it looks as if the content is the problem.
    Boanerg Friend
    #211191
    It is the following module which causes this:
    mod_extcalendar_minical (on the right collume)
    Is this something that can be fixed? Where do I have to start?
    Khanh Le Moderator
    #211194
    Boanerg,
    I cannot access your site: http://www.boanerg.com/web
    Boanerg Friend
    #211204
    I’m sorry! I have moved the site to http://www.music-event-page.de
    I had to do this because the old site was hacked.
    Also I disabled the modle
    Khanh Le Moderator
    #211216
    The banner image cause the error. Please make the width of the banner smaller.
    rodoart Friend
    #211296
    Hi guys,
    I’m facing the same problem with IE. I’m using IE version 6.0.2900.2180.xpsp_sp2.gdr.050301-1519
    I’ve removed all modules from the right column and put them back one at a time but nothing changed. I’ve done the same with the contents and modules from the central column or the main body if you prefer, and nothing happened unless I remove all central content and modules. Only then the right column modules start from the top of the column.
    What shall I do to fix the problem? Why everything works ok with firefox?
    here is the address of my site… http://rodotheos.net/selitsani (it’s a Greek site by the way).
    Thank you in advance,
    Theo.:((
    Khanh Le Moderator
    #211304
    The module Minical Extcalendar cause this problem. Open file mod_extcalendar_minical.php in folder modules, find these number 135 and 139, replace them with 100%.
    That this module fixes its width brakes the JA Zibal layout in IE.
    nathans Friend
    #211309
    I am also having issues with IE7 and my JA Shopping II template.
    rodoart Friend
    #211324
    Khanh, I have done the changes you told me …
    That this module fixes its width brakes the JA Zibal layout in IE.</blockquote>
    but nothing happens. I’m still facing the same problem. Any other ideas?
    terence Friend
    #213118
    <em>@khanh 3304 wrote:</em><blockquote>The module Minical Extcalendar cause this problem. Open file mod_extcalendar_minical.php in folder modules, find these number 135 and 139, replace them with 100%.
    Khanh,
    This is an ongoing problem. Why is it that you don’t rather tell us how to make the template compatible with standard joomla modules? Why can we not get a solution from you how to make the right column wider? I can not see a template being for sale and it does not fulfill the needs of the buyers. Basically what i am understanding, is that every time this problem comes up, you explain to us how to not use modules we actually need on our websites. Give us a template solution please? My site has the same problems: http://www.healing-health.co.za
This topic contains 13 replies, has 8 voices, and was last updated by  terence 17 years, 11 months ago.
