Viewing 15 posts - 1 through 15 (of 17 total)
  • msilac Friend
    #170068
    I have some weird problem with IE browser… I use IE 8.0 and http://www.Osijek-Online.com have problem wit showing Ja tabs, pop up script, latest news script… In all other browsers everything is fine. maybe absolute paths… or something
    Can we fix that?
    Here is what I have from errors in IE
    Webpage error details
    User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; Trident/4.0; SU 3.28; GTB7.1; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0; Tablet PC 2.0; .NET4.0C; InfoPath.3)
    Timestamp: Wed, 26 Oct 2011 07:45:04 UTC
    Message: ‘undefined’ is null or not an object
    Line: 27
    Char: 3
    Code: 0
    URI: http://www.osijek-online.com/media/system/js/caption.js
    Message: ‘this.el.offsetWidth’ is null or not an object
    Line: 37
    Char: 3
    Code: 0
    URI: http://www.osijek-online.com/plugins/content/ja_tabs/ja.tabs.js
    Line: 16
    Char: 3
    Code: 0
    URI: http://www.osijek-online.com/modules/mod_janews_fp/tmpl/default/script.js
    Line: 37
    Char: 3
    Code: 0
    Line: 3838
    Char: 1
    Code: 0
    Line: 26
    Char: 6
    Code: 0
    URI: http://www.osijek-online.com/modules/mod_janewspro/assets/js/script.js
    Message: ‘$$.shared.regexp’ is null or not an object
    Line: 55
    Char: 716
    Code: 0
    URI: http://www.osijek-online.com/media/system/js/mootools.js
    msilac Friend
    #421917
    Hello, can someone help me?
    msilac Friend
    #422457
    <em>@msilac 279126 wrote:</em><blockquote>Hello, can someone help me?</blockquote>
    I would appreciate any help
    msilac Friend
    #423339
    Now it is urgent… support please! 🙁
    msilac Friend
    #424505
    I have live site and problem with template, please, I need help!
    msilac Friend
    #425253
    What should I do to get an answer?
    Thank you
    n6rej Friend
    #426021
    wow, I dont’ know how you fell through the cracks but I commend you on having the patience of job!
    i’m going to push you to a ticket so we can get you going.
    msilac Friend
    #426161
    Thank you!
    msilac Friend
    #433891
    Nothing about that?
    n6rej Friend
    #433900
    your ticket has vanished… I can’t even find it in the system which is strange… would you please update all your JA software via JAE and let me know if you still have the problem… I’m really sorry about this I don’t know what the issue is.
    msilac Friend
    #433902
    Can you just look http://www.osijek-online.com so that you can confirmed that you see same problems?
    n6rej Friend
    #434160
    I did and quite honestly I don’t see the issue.
    msilac Friend
    #434165
    I have upgraded extensions and everything else… problem (about IE) was at IE 8.0…
    n6rej Friend
    #434168
    <em>@msilac 295156 wrote:</em><blockquote>I have upgraded extensions and everything else… problem (about IE) was at IE 8.0…</blockquote>
    I used f12 mode ie8 and don’t see the issue.. can you tell me how to replicate?
    msilac Friend
    #434170
    I dont know… I have IE 9.0 now and it i s ok 🙂 I dont see that like a problem anymoore… I have problem with background but that is other topic…
This topic contains 17 replies, has 2 voices, and was last updated by  msilac 12 years, 11 months ago.
