  • mahdi_asadi Friend
    #190192
    hi there , i set the ja-university template for the “teal” one , but when i use internet explorer 6 – 9 it uses green theme how can i change it to “teal”
    thanks in advanced
    Hi mahdi,
    What do you mean by ‘teal’ one here?
    And I do not see active club membership in your profile, this JA University is a commercial template, support and download access are available only to active paid members. Please signup and be our club members and i will try to help you then.
    mahdi_asadi Friend
    #504943
    at last i could pay for membership from third party because i live in iran and we are under sanction :((
    i mean” teal theme “
    maybe i have imperfect version ja_university that shows this problem ? i download it from other site
    please check my site at this url:
    http://www.uni.zhanpal.com/
    could you help me to solve my problem ?
    any advice will be appreciated and thanks in advanced …
    Could you also send me correct url to access the admin site?
    BTW, pls try to make sure that you assign profile which using ‘teal theme’ to correct menu item page and clean JAT3 cache.
    mahdi_asadi Friend
    #504969
    i send it by private message ….
    mahdi_asadi Friend
    #504978
    thank you Saguaros
    the problem of showing green theme instead of teal is solved by your guidance : i used 3 theme in theme settings : TEAL , GREEN , DEFAULT so i delete green and now my site appear with teal theme when i use IE under 10 version , but not properly for example it dosn’t use logo that i want to use for persian language and it doesn’t use rtl css please check it with IE (under 10) and other browser to see differences
    thanks again for your guidance and i am waiting for your more guidance…..
    Could you make screenshot of problem with the logo in IE browser here? I tried with IE9, IE8 but the logo is the same as opening in other browser:
    http://i.imgur.com/QmWEiJt.png
    mahdi_asadi Friend
    #505001
    i use IETESTER program to check IE compatibility
    following screenshot is for IE9
    http://i.imgur.com/YgIjAlL.png
    and this for IE8: http://i.imgur.com/mQDOiaX.png
    mahdi_asadi Friend
    #505004
    for assure i went to coffee net and used their IE7 and i captured a screenshot : http://imageupload.co.uk/files/r8h36a8z6m6iachi6u9i.jpg
    Dear mahdi,
    But I don’t see the different in logo, please try to open your site in these versions of IE (except for IE7 since we haven’t supported IE7 anymore) and tell me the difference so that I can help.
    mahdi_asadi Friend
    #505181
    hi Saguaros
    when you browse http://uni.zhanpal.com with IE10 and upper and chrome or firefox you will see in the logo for persian language (default) and every thing is in right to left (LTR)mode but
    when you browse http://uni.zhanpal.com with IE 8-9 you will see in persian language (default) and menu and news part are in left to right(LTR) mode
    IE8 :
    chrome :
    1. Nmgc
    2. Pmgc
    3. logo
    4. logoen
    mahdi_asadi Friend
    #505259
    i found that when i browse uni.zhanpal.com with IE(7-8-9) it doesn’t use rtl css look at the following pictures :
    IE10:
    as you see above logo used “templates/ja_university/themes/default-rtl/css/template.css”
    IE9:
    and the following css used for logo in IE9 :” templates/ja_university/themes/teal/css/template.css”
    i have tested and browsed my site with so many different computers that is installed IE less than 10 , and you should not trust on
    browser mode of developer tools in IE (it’s wrong to use this tool to see how IE shows in different versions at least for this case ) and i am assure that when somebody browse site with IE <10 this problem will occur
    Joomlart developers i need your helps please assist me
    1. dbug-IE10
    2. dbug-IE9
    Hi mahdi again,
    Try going to template manager > open style appearing with your RTL language > set Optimize Css to Yes and open in IE8 again.
    IE browser limits the number of css file loaded so it may cause this issue.
    And let me know how it goes.
    mahdi_asadi Friend
    #505460
    Saguaros you are awesome ! :-* it works 🙂
    best wishes for you
    1. thank-you
    You’re welcome, mahdi :p
This topic contains 15 replies, has 2 voices, and was last updated by  Saguaros 11 years, 3 months ago.
