Viewing 15 posts - 1 through 15 (of 22 total)
  • thomaskremer Friend
    #141390
    I have a problem with IE8: the top of the template is mixed up in my website (http://www.stjan.org).
    Could anyone help me?
    turnerje Friend
    #307074
    I am having the identical problem with IE8. Any support would be appreciated.
    theprofessor Friend
    #307076
    Here’s a post over at joomla.org from someone who fixed his similar problem with JA Purity template.
    May be worth giving it a try.
    http://forum.joomla.org/viewtopic.php?f=541&p=1709079
    theprofessor Friend
    #307077
    There’s also this message from a month or so ago from Hung about updating all JA templates to fix IE8 bugs.
    Again — not sure if it will help, but perhaps worth a read for informational purposes.
    http://www.joomlart.com/forums/topic/all-templates-updated-to-joomla-1-5-10-bug-fixes-for-official-ie8/
    marm Friend
    #307137
    <em>@thomaskremer 129791 wrote:</em><blockquote>I have a problem with IE8: the top of the template is mixed up in my website (http://www.stjan.org).
    Could anyone help me?</blockquote>
    Hay thomaskremer, how did you get on finding a fix?
    I’m also having problems with IE8 and a new install of JA Rutile , installed with the quickstart.
    The News drop down covers the top of my articles on the front page.
    Also having crazy spacing problems.
    seem to work fine when you tell ie8 to run in compatibility mode.
    marm Friend
    #307138
    <em>@theprofessor 131684 wrote:</em><blockquote>Here’s a post over at joomla.org from someone who fixed his similar problem with JA Purity template.
    http://forum.joomla.org/viewtopic.php?f=541&p=1709079</blockquote>
    Thank you , this fix seemed to do the trick.
    thomaskremer Friend
    #307139
    Yes, in fact its easy:
    In the index.php at templatesja_rutile , change
    into
    For me, the problem disappeared. Hope it will work for you.
    Thomas
    marm Friend
    #307140
    <em>@thomaskremer 131759 wrote:</em><blockquote>Yes, in fact its easy:
    into
    Thomas</blockquote>
    Yes that fix works well 🙂 , I.E 8 still moans saying that the site is designed for older browsers and gives you the option for compat mode.
    But the site seems to load ok.
    mj1256 Friend
    #307152
    tversover Friend
    #307753
    Hi!
    I also tried to change
    into
    and also get the message in IE 8 that the website is designed for older browsers. But the thing is that the website looks hottible in older browsers, so that is not true. How can I make IE8 not say that?
    http://www.tversover.no
    Thanks!
    marm Friend
    #307758
    <em>@tversover 132518 wrote:</em><blockquote>Hi!
    into
    Thanks!</blockquote>
    Try the extension that mj1256 suggested. Did the trick for me.
    tversover Friend
    #307759
    I have already innstalled that. I may have helped with IE 8.0, but not with 7.0. Is there a similar extensions to fix bugs in 7.0 and older?
    tversover Friend
    #307760
    And also, would the extension fix the problem with IE 8.0 saying the website is made for an older version? It didn’t in my case. How could I fix that?
    Thanks again
    marm Friend
    #307761
    <em>@tversover 132525 wrote:</em><blockquote>I have already innstalled that. I may have helped with IE 8.0, but not with 7.0. Is there a similar extensions to fix bugs in 7.0 and older?</blockquote>
    Have you tried the different settings in the extension, you get a drop down box from within the extension settings to run the site in a different modes. Give that a test.
    Hope that works.
    tversover Friend
    #307763
    Oh, I didn’t know that. Is it the one called “System – IE8 Compatibility”? If yes, it seems to have been deactivated. Do you have any tips on what to change to in the drop down menu? Could this also fix the problems I have with JA News in 7.0 you think??
This topic contains 22 replies, has 8 voices, and was last updated by  tamerax 15 years, 4 months ago.
