January 28, 2017 at 12:07 pm #1006301
Problems appear few days ago:
- cant load images to blocks
- list text here blocks view dissaper in page builder (when choosing new block- look attached file)
only I have that problem ?
italpascal Frienditalpascal
- November 2014
- 3 times in 1 posts
January 28, 2017 at 1:19 pm #1006307I jabuilder beta 1, I do not understand why this situation
see image Template_advanced is white.png🙁
Ital Pascal- Arvind Chauhan Moderator
Arvind Chauhan
- 1334 times in 848 posts
January 29, 2017 at 2:18 am #1006365Hi guys,
I checked the issue from my side and it is working fine, could you please check if it still happens?
If issue is still there, please share with me your site info, mark the reply as private to secure the info.Regards.
1 user says Thank You to Arvind Chauhan for this useful post
- November 2014
January 29, 2017 at 10:51 am #1006532I do not know what happened, now I see the image regularly 🙂
Ital Pascal
January 29, 2017 at 4:43 pm #1006575I do not know what happened, now I see the image regularly ?
me too, but still cant load images to blocks (when i choose them in block propierties overley – they dont automaticly copied from my PC to media/jub/images/default/, i can manually add them to media/jub/images/default/… write the adress in block propierties overley and only then they works fine)
January 31, 2017 at 8:03 am #1006943Great to see it working back now. The images are on Amazon Cloud so it could be some issue with the server or could be internet connection.
Let me know if you have any other issue.
Regards.
AuthorPostsViewing 6 posts - 1 through 6 (of 6 total)This topic contains 5 replies, has 3 voices, and was last updated by Arvind Chauhan 7 years, 10 months ago.
