  • timvdp Friend
    #141637
    My Pictures that i post all have a black border around them and are being squeezed
    hanifahmed Friend
    #306554
    Can we get a live link to see?
    Could be that your images are sized incorrectly. Could be too wide for the module your trying to view it in.
    timvdp Friend
    #306556
    http://localcounseldallas.com/cptlawfirm.com/09/index.php
    The pictures are fine they pull fine in the media folder
    hanifahmed Friend
    #306558
    They’re resized images.
    What extension are you using to display the articles?(sorry dont have time to inspect properly)
    timvdp Friend
    #306572
    it’s a simple article with front page enabled. It has to be a CSS call from the template but i can’t find from where
    timvdp Friend
    #306575
    Found the solution … the images HAVE to be 150 by 150 otherwise back borders show up…
    sangvalte Friend
    #318085
    This is because of the frontpage override by Ja Tube template.
    Go to templates/ja_tube/html/com_content/frontpage/
    Rename default_item.php and default.php files, and you won’t have this problem.
This topic contains 7 replies, has 3 voices, and was last updated by  sangvalte 15 years, 3 months ago.
