  • rayfurre Friend
    #164350
    Please check woolland.no as you can see the image of the frontpage article is strangely in the upper left corner, apart from that there are no images showing for position user6 and most read and latest news in positions user1 and user2.
    I did submit admin info with ticket.
    Please advice.
    khoand Friend
    #392622
    Could you give me username+password of ftp?
    rayfurre Friend
    #393364
    DId send you ftp info in PM thanks
    khoand Friend
    #393425
    I can’t access your ftp. Could you give me content of modulesmod_jabulletintmpldefault.php file (attached file)?
    rayfurre Friend
    #393503
    I resent ftp info, I tried to upload file but it says invalid file
    rayfurre Friend
    #394316
    Any one please ?
    Phill Moderator
    #394320
    The articles you have on that page have images linking to an external source. Please insert your own images.
    For instance the “iPhone bestselger i Europa” article has an image linked to one on the JA website “http://templates.joomlart.com/ja_quartz/images/stories/demo/sam-1.jpg
    As this image exists and is viewable if I browse to I I can only suggest that your server is blocking it in some way. If you use your own images in the article linked locally then you should not have a problem.
    khoand Friend
    #394353
    phill luckhurst is right. I used internal image to Pretium Lorem id Ut at commodo aritcle (01.06.11) and it works. You check your site, please
This topic contains 8 replies, has 3 voices, and was last updated by  khoand 13 years, 6 months ago.
