  • amir2005 Friend
    #1016403
    After update, I have the e php extension : index.php/en/
    http://asmeratimes.com/index.php/en/
    Pankaj Sharma Moderator
    #1016437
    If you have only one language installed on site and do not want to use the language extension I suggest you to disable the language filter plugin from plugin manager of your Joomla.
    Hope it helps.
    amir2005 Friend
    #1016739
    Pankaj
    Thank you. I have the following on my website. http://asmeratimes.com/index.php/en/
    How do I remove index.php/en?
    amir2005 Friend
    #1016749
    Hey your advise worked…
    now I have a problem with article sticking and scrolling coming out from the right side
    Thank
    amir2005 Friend
    #1016751
    I have the website on line now http://asmeratimes.com/
    #1016752
    Thank
    Great it works.
    Please open a new topic for a different subje question. It also helps other users.
This topic contains 5 replies, has 2 voices, and was last updated by  Pankaj Sharma 7 years, 6 months ago.
