  • vnav Friend
    #188852
    I would make “content -top” mainbody biger so I has disable all module in “inset” position (Popular article,s Last articles..)
    Problem with Infinity scroll (auto load items when scroll down)
    – In PC Desktop : working
    – In Ipad, Iphone : not working
    How can I fix it ?
    thank
    phong nam Friend
    #498818
    Hi vnav,
    Thank you for your feedbacks. I has transfered this issue to our dev team for the bug fix in the next update of JA Argo template. You can track on our work flow at http://pm.joomlart.com/browse/JATCARGO-131. I will back to inform you when the new update of this template is available.
    vnav Friend
    #501252
    Hi Leo Burnetts
    Any new for fixing this bug ?
    phong nam Friend
    #501345
    Hi vnav,
    I has reminded our template developer about this raised issue, and the bug fix will be included in the next major update of JA Argo template. Thanks you !
    phong nam Friend
    #501407
    Hi vnav,
    Now, you can solve this issue by opening templatesja_argojsscript.js, replace lines (307th):
    if((('ontouchstart' in window) || window.DocumentTouch && document instanceof DocumentTouch) && (inset.offset().top > $(window).height() / 2)) {
    return false;
    with
    if((('ontouchstart' in window) || window.DocumentTouch && document instanceof DocumentTouch) && (inset.length && inset.offset().top > $(window).height() / 2)) {
    return false;
    The red texts are additional codes., make sure that you backup the file before applying update.
    vnav Friend
    #501487
    I had add this red code to script.js… work like a charm
    thank you
    Eugene Friend
    #502904
    Hello.
    infinity scroll does’t work correctly on the main page. it’s load only one block of articles and that’s all.. Other blog categories works OK. Help me please)
    http://zdravnica.net
    phong nam Friend
    #502942
    Hi oppositeby,
    You can try to go Skype Status module’s backend, then set No to Include jQuery, the Infinity scroll will work fine as usual.
    Eugene Friend
    #502973
    Leo Burnetts, thank you so much! You are absolutely right!
This topic contains 9 replies, has 3 voices, and was last updated by  Eugene 11 years, 4 months ago.
