  • benrud Friend
    #136813
    Hello Everyone,
    I’m having trouble putting a flash video file into this template.
    The FLV will play but the FLV player skin will not show up when inserted into a content item. The same file will play when inserted into a plain html or php page though. links below.
    FLV File in the template
    http://benrud.net/index.php?option=com_content&view=article&id=85:paul-and-gabby-playing-with-elmo&catid=25:paul-videos&Itemid=157
    FLV File in a simple php page
    http://benrud.net/benrud_files/videos/2009/xmas-2008/index.php
    I’m totally confused…. any ideas?
    Thanks for your help.
    Todd
    bennitos Friend
    #285221
    Hmm not sure, but what you could try is the following.
    When you add a flash to a article you can set a couple options for it, standard is enabled:
    “Auto play” “Show menu” and “Loop” try to turn these off as you have a menu build in your flash file.
    You will find those settings under the advanced parameters of the flash object.
    Not sure if this wil solve it but its worth the try.
    benrud Friend
    #285225
    bennitos,
    thanks for the ideas, I’ll try it when I get home tonight but I don’t think that is the problem. I’ve messed with the setting, I’ve tried adding the code to a content item, loading it as an external item and as a jumi item. Non of them worked.
    All I know is when I publish the code as a seperate file it works correctly and when I add the same file or code into the joomla system it only plays the FLV not the playback skin.
    Thanks,
    Todd
    bennitos Friend
    #285226
    I have Avian here running aswell, if you want i can test on here to see if it works?
    If so can you send me the flash file, and ill send you a msg when its up.
    benrud Friend
    #285244
    Bennitos,
    Thank you for your help. When I get home tonight I’ll post the FLA, SWF and FLV so you can download them.
    Thanks again,
    Todd
This topic contains 5 replies, has 2 voices, and was last updated by  benrud 15 years, 11 months ago.
