  • dlachman Friend
    #178659
    hello
    After succesfully FTP all folders from quickstart folder to public_html and trying to access my site, i recieve the last screen of instalation that ask to delete instalation folder. cant go back to define DB and if i delete the installation folder i recieve a “page not found” error message
    Cao you assist pls?
    Thanks in advanced
    <blockquote>i recieve the last screen of instalation that ask to delete instalation folde</blockquote>
    Usually this happens when your public_html folder contains some files from a previous installation ( configuration.php )
    To avoid this, you need to start from scratch a new installation and you need to be sure that your public folder was empty before start again
    also make a new database and use it for your new installation
    dlachman Friend
    #459396
    Thanks, done, i cleaned all public_html folder and upload again all quickstart folders. Installation starts, all steps are ok but after i insert all DB parameters (user, pass etc) i wait more than an hour and nothing happend (try 3 times)
    – “next” is not enable and i cant go to next screen
    Thanks in advance for your assitance
    Check better your db configuration (username and password . etc ) after you have checked these settings you need to be sure that your user has all the rights . you need to grant for all ( some servers has the option to check the rights for new created db user )
    Hope that helps
This topic contains 4 replies, has 2 voices, and was last updated by  pavit 12 years, 5 months ago.
