April 13, 2015 at 7:56 am #205488
OS Win 8.1 64 bit
Wampserver (64 bits & PHP 5.5) 2.5Quickstart installation did not work, please see attachments ( 001 – 002 – 003 ).
I do as it say in the Documentation, Open the php.ini then configure as below
post_max_size = 750M
upload_max_filesize = 750M
memory_limit=750Mplease could you help me with this ?
Thank you
- Ninja Lead Moderator
Ninja Lead
- November 2014
- 3854 times in 3563 posts
April 14, 2015 at 8:18 am #566880I would like to check this bug directly on your site, please pm me URL of your site and admin login. I will help you to detect it
April 14, 2015 at 1:11 pm #566912Dear Ninja,,,
i have my website, but now i using in localhost, when i am finsh my new website i will do in online.
Thank you
jooservices Friendjooservices
- October 2014
- 1245 times in 1121 posts
April 15, 2015 at 2:13 am #566966<em>@ashraf tayab ja 468307 wrote:</em><blockquote>Hi,
OS Win 8.1 64 bit
Thank you</blockquote>
Hi there
About blank page please turn on display_errors to get more detail.
Note:// Joomla! use ini_set to override it. Please make sure you set Debug mode in Joomla = Development.Thank you,
Viet VuApril 15, 2015 at 10:09 am #567031jooservices Friendjooservices
- October 2014
April 15, 2015 at 2:51 pm #567077Hi there
Pingo. Please increase max_execute time in your php.ini and restart apache.Thank you,
Viet Vu1 user says Thank You to jooservices for this useful post
April 15, 2015 at 3:32 pm #567091Hi jooservices
first of all i would like to thank you for your help, THANK YOU
it is work good.
one more question please, what is the best number should i use ( max_execution_time = ??? )
Thank youjooservices Friendjooservices
- October 2014
April 15, 2015 at 3:46 pm #567095Hi there
So hard to answer that. It’s depend on your server .
Put it so high will cause server crash if server is weak.Thank you,
AuthorPostsViewing 8 posts - 1 through 8 (of 8 total)This topic contains 8 replies, has 3 voices, and was last updated by jooservices 9 years, 6 months ago.
