May 27, 2008 at 6:16 am #128944
hello
I downloaded JA_FEDORA and i am trying to upload it on the server. I did unzip the file ja fedora v1.1 for moomla 1.5 and used the template zip file to upload the template. however it says that the xml file can not be found.
This is crazy. I spend 49 dollor for something that is not workingtempusserbia Friendtempusserbia
- January 2008
- 32 times in 8 posts
May 27, 2008 at 7:12 am #250692Why are you trying to upload it?!
Open your Joomla administration page, then go to:
1.Exstensions > Install/Uninstall,
2. go for the first one,
3. Click Browse, find your template.zip file on your HDD and then click Upload File and InstallMay 27, 2008 at 8:00 am #250708well i just went to Installer -> templates-site and then browsed to the folder it had the template file and selected it and uploaded that way. I get the error message that that xml file is missing.
i MEAN i uploaded other templates into joomla and it is not that hard but this one does not have everything i guess or maybe i am still doing it wrongtempusserbia Friendtempusserbia
- January 2008
May 27, 2008 at 9:41 am #250720Do you try to download it again? Also, are you trying to install plain template or quick start template?
soulroll Friendsoulroll
- May 2008
May 27, 2008 at 11:44 am #250729Hi , i have the same problem. unable to install quick install. i installed then the normal template but without all the modules.
I paid for that site, so please make it able to install the quick install. i need it!!!!!!tempusserbia Friendtempusserbia
- January 2008
May 27, 2008 at 12:40 pm #250730I’ve tried both templates, plain one and quickstart and installation goes without problems. Guys you must doing something wrong.
Look in download section, there is JA Fedora v1.1 for Joomla 1.5.2 : (Include template and quickstart) (6.07 MB), so you have separate archives in it, one for plain template, and other one for quick start. It’s two different things. If you tried to install it as it stand above, then you will get that error message.
Unpack above archive, find two template archives (plain and quickstart) and then try to install them as archives.
- May 2008
May 27, 2008 at 12:46 pm #250731sorry but i just did it the 2nd time again. i deleted joomla complete and install the quick install, but the same problem again. after putting in my ftp details and wanna choose the template the error comes up. it never happened to my with another quick install before
May 27, 2008 at 8:21 pm #250791Ok i got it installed. The problem I had was i had a old version of joomla on our server. after upgrading to the new version it installed.
Another problem that i ran into is installation of catpopup modual. I got it installed but it is not working correctly. it just shows the header for the section that is getting assigned to and when i click on it there is popup but nothing is shown. in the user guide it mentions
To make this work you need to have one copy of this module published to a module position called catpopup
howerer when i look under the template configuration where i select the position there is not such position. so i put it under position 2 which is named “topsl” . where do i add that name for the position?
- January 2008
May 28, 2008 at 5:49 am #250819soulroll Friendsoulroll
- May 2008
May 28, 2008 at 10:01 am #250849third time installed the quick install and still xml file missing!!!! with other quck install ja templates it doe work…
- May 2008
May 28, 2008 at 10:28 am #250852here a quick snapshot of my problem…the forth instalation try!!!!!!
that comes everytime i wanna install the sample data.
Menalto FriendMenalto
- May 2007
- 531 times in 361 posts
May 28, 2008 at 11:25 am #250857Try to drop the sample data,but import the sampledata.sql with phpmyadmin or another database tool you have after installation is complete and see if it works then.
This topic contains 12 replies, has 4 voices, and was last updated by Menalto 16 years, 7 months ago.
