October 11, 2011 at 3:43 am #169549
Hi, I already installed manually all files but I don´t know where to put the JA Social Source. Can someone please help me and tell me what to do with it? Thank you very much in advanced.
jooservices Friendjooservices
- October 2014
- 1245 times in 1121 posts
October 11, 2011 at 3:44 am #418370<blockquote>I don´t know where to put the JA Social Source</blockquote>
May i know what are you looking for JA Social source ??? Not really understand what are you doing ? Please a bit explain.
Thank you
Viet VuOctober 11, 2011 at 7:42 am #418401Hi, Okay I will try to explain better. Thanks for your patience, I am new at this stuff. I didn´t manage to do the quick installation for the JA Social template, so I uploaded all the compontents, plugins and modules through the backed of joomla and it worked. I always git a succes message. Then I went to the FTP and I put the JA jomsocial template in the folder for the Jomsocial template. That also worked fine. But now there is one part missing for installation and I don´t now where I should upload it or what else to do with it. It is called ja_social_source.zip.v1.0.0.zip and contains a folder ja_social_source which contains two folders fonts and psd.
Can you please tell me what to do. Thanks for your help adn patience in advanced.jooservices Friendjooservices
- October 2014
October 11, 2011 at 8:59 am #418421Hi,
The ja_social_source.zip.v1.0.0.zip you are talking is it a Joomla template or jomsocial theme ?
If possible could you please upload it into forum so i can take a look for you.
Viet VuOctober 11, 2011 at 4:16 pm #418495Hi, I don´t know how to upload the file here. But this is the link http://www.joomlart.com/forums/downloads.php?do=file&id=1809 to download it. It is the only one of this list http://www.joomlart.com/forums/downloads.php?do=cat&id=10334 (besides the quickinstall that I didn´t use) that I don´t know what to do with it. Thanks again for your help. Mauricio
- October 2014
October 12, 2011 at 12:40 am #418568Hi
I’m really don’t know why do you need upload source files into your site ?
Please note: http://www.joomlart.com/forums/downloads.php?do=file&id=1809 ( Source file ) is a pack for PSD and any images related w/ this template. It IS NOT template .By install template you can download this one: http://www.joomlart.com/forums/downloads.php?do=file&id=1800
and install it via Joomla InstallerFor JomSocial theme : http://www.joomlart.com/forums/downloads.php?do=file&id=1802
You can download it and upload it into JomSocial theme folder and select it at backend of JomSocial.Actually, if you are new in Joomla i suggest you go w/ quickstart for easier 🙂
Thank you
Viet VuTomC ModeratorTomC
- October 2014
- 3155 times in 2495 posts
October 12, 2011 at 12:45 am #418571If installing the JA Social Template – to resemble the demo version – is the issue, then I highly recommend following this
STEP-BY-STEP GUIDE for performing a quickstart installation (with sample data).If you’re wondering “why use quickstart” –> The VALUE of the Quickstart Installation
This topic contains 7 replies, has 3 voices, and was last updated by TomC 13 years ago.
